Nettiä koluttu ja kaikkee koitettu mutta ei, tää ei ainakaan asiaa auta
Muutkin huomanneet samanby looking at the schem there is no on/off switch for the pre-amp. it would be easy to add one by pulling one leg of R3 up and bridging this with a switch.
Niin, tekis modin jos se järkevänä jostain löytyis..? Ei viittis disabloida kokonaan poistamalla releitä tms..What I don't like about that amp is that the pre-amp is on whenever the unit is one, until you do a mod to disable that function. Also, this is a class-C amp, unless you've done some modifications to convert it to class AB/AB1. Out of the box, the 300P is class-C.
